In the batch area
Click on doors/drawers. Select a standard slab door set the width to 18 and the ht. to 21
Click on add door. It will load 1 door
change the quantity to 30
Click on the cut list. The sheet stock summary shows just 1 sheet
The only way to get the quantity of sheets is to nest then go to the cut list (by the way as for me this is the preferred method any way)
If you just keep clicking on the create door button 30 times then the cut list will show 4 sheets as the quantity before nesting
Now delete all. Then load a cabinet back for example. Set the width and ht. to 18x21 and the quantity to 30 and click ok
Click on the cut list. The sheet stock summary shows 4 sheets before nesting even if you load just 1 back and then change the quantity to 30.
