Partition Error
Nat Wheatley
Partition Error
Post by Nat Wheatley »
I cut the attached cabinet today, and the shelf holes in the partition were about 1mm deep. I'm using the SB Link, set to metric.
11.hsf
(1.15 MiB) Downloaded 378 times
Scott G Vaal
Re: Partition Error
Post by Scott G Vaal »
Nat,
Which part are you having trouble with? There is not a partition in the attached cabinet. I looked at all the other parts and they seem to have correct hole depths in the CNC output. If you would, please send us an export from your SB link and I will take a look at it.
Nat Wheatley
Re: Partition Error
Sorry, this is the correct cabinet. Not clear on how I attached the wrong one last time, but I did.
I'll send an export file from the SB Link in the morning.
Partition.hsf
(3.09 MiB) Downloaded 402 times
