display panel
nick staub
- Company Name: mcmanus dev
display panel
I have a cabinet with a clipped corner.ive taken all horizontal parts to part editor and chamfered each corner.i then created a display panel with dimensions to fit clipped corner.then rotated and aligned and have it on the cab.but now when I save that cab,it does not save the display panel on the cab.????what am I doing or not doing???
- Scott G Vaal
Re: display panel
Nick,
You need to associate the panel to the cabinet. If you have a cabinet selected when you add a panel in, it will automatically be associated to it. Now, if you forgot to do this step, you can select the cabinet (double-click it to select all edges green) then select the panel (single-click to hatch it green), Right-Click and go to Associations -> Associate to Cabinet. You can tell if it is associated by hovering over the panel, if the tool tip states a cab number at the top, it is associated to that cab. Hope this helps.
nick staub
Re: display panel
associate to cabinet....got it
Dennis Englert
Re: display panel
Another way to tell. If you double-click on a display panel, the entire cabinet will be selected if it is not associated to the cabinet.
If you double-click the cabinet before you insert the Display Panel, it will automatically be associated with the selected cabinet.
Dennis
Dennis
