Jewelry Armoire
- George Davidson
Jewelry Armoire
One opened up and one closed.
I give up on the lighting
Sizes 21 W x 38 H x 14 D
- Brian Shannon
- George Davidson
A little better lighting
Spot light
- Kerry Fullington
- DanEpps
- Company Name: Dan Epps
Re:
There you go George, straight from the "Master of Presentation" himselfKerry Fullington wrote:George,
Great presentation.
If you haven't noticed, the presentations on the eCabinet Systems homepage (http://www.ecabinetsystems.com) are Kerry's.
Dan
- George Davidson
Thank You Guys
Help on my stone wall
It is 41 7/8\"W x 36 1/2\"H x 1\"T
I Put the Stone image on it now how do I get it
to the right sizes?
I was going to try to make a fire box for my mantel.
HELP [/flash]
to the right sizes?
HELP [/flash]
- Kerry Fullington
George,
If it is a display cube when you select the image you can then choose to either stretch the image or set the tile sizes to get the image size you want. You can also export the display cube to the display part editor where you can change the image size and orientation and save the cube as a display object.
