A lot of my cabs are mixed. I have FFs surrounding the outers of the cabinet and the insides are Euro, meaning tight margins (5/64") between doors with only the partition or fixed shelf behind the door/drawer.
I remember being able to put a pair of doors into the cabinet by using a large offset on one side and then doing the opposite for the other side. Now as soon as you put the first pair of doors in it doesn't let you highlight the empty area to put the other doors in.
My work around was to put FFs on the partitions that are the same thickness and then use a negative offset to have the doors overlap the FFs. I don't remember having to do this in the previous versions.
