Audrey, Left click a shelf to highlight. Then right click, go to visibility and click transparent. Better yet hold down Cntl key as you highlight each shelf, then go to visibility, and transparent.
Make a Display cube the size of your shelf then do the texture match as Jody said. You can then copy and paste the rest of the shelves. If you want the material to show up on cutlists, create a sheet stock called glass then make your shelves as display panels from this material. You still have to do the texture match once the shelves are in the cabinet. Don't forget to associate the display panels or cubes to your cabinet before you save.
I never thought about this! That's great! Now I'll have really glass shelf! Youshould see the one I was doing befor it was so rubbish!! (hope this is the good word in english)...
Ton experience va au-dela du dictionaire.
Quand j'ai demenage a Calgary il y a 24 ans, j'avais l'anglais du dictionaire et c'etait pas aussi bon que ton anglais.
Bonne Chance et Joyeux Noel.
Jean-Gabriel Voyer
Janot Interiors Ltd www.customcabinetscalgary.com
Je sais le sentiment de mes propres ecpreiences en France. Si vous apprenez au Français spean dans le sud, personne à Paris ne peuvent vous comprendre! Le plus, mon dictionnaire est électronique
