I searched the forum for being able to export my eCabinet files in a format other than *.twd with no luck unless I didn't search correctly.
A shop i want to use for frameless cabinets does not have a Thermwood CNC and mostly uses Auto Cad, does anyone have a way that this is done?
Thanks in advance
Exporting eCabinet files for other CNCs
- Clint Buechlein
Re: Exporting eCabinet files for other CNCs
ECabinets will only output a .twd file to be read by a Thermwood router, or a ShopBot with the purchased link.
- Neville Bastian
If you ask Thermwood they may be able to supply Thermwood owners in your area?
Regards
Neville
Regards
Neville
Neville Australia
- Josh Rayburn
JR,
We have a Thermwood router, and we cut parts for professional cabinetmakers. In fact, that's all we do.
Give me a call if you like, I'm sure we can help you with your machining requirements.
Thank you,
JNR
Thank you,
JNR
- Clint Buechlein
In regards to to this post, we will not give out any company's information without their permission to do so. To eliminate the need for us to keep a list of business names around to give out, we created the Produciton Sharing link from the eCabinets webpage.Neville Bastian wrote:If you ask Thermwood they may be able to supply Thermwood owners in your area?
Regards
Neville
http://www.ecabinetsystems.com/ecabinet ... ration.htm
We do often get requests for Thermwood routers in particular areas, we always refer them to the Production Sharing site, or to ask here on the forums.
