Problems with sheet selection option
DanFecteau
When I try to go to a 2 digit sheet I am not able to do it, I receive something like : \" Unable to call label \"
Hi Dan,
The reason you are seeing this issue is because of a variable set in the MSU file of your machine. I looked up your machine file and found the setting. We will need to make a change to the setting and send you an updated MSU file. Please contact me (800 221 3865 ex 247)so I can verify the machine number(Located on an Alum. serial tag on leg of machine) that I researched. I tried to call the phone number that I have for your company and did not get through.
