Is there a way to export the cut list to full version of Excel? I tried, but it won't happen. Since my door supplier has a 2 sq. ft. min. on doors/drawers fronts, I wanted to export and use a formula to get actual size and then add another foot if needed.
Thanks, Jon
Export to REAL Excel
Jon Forsgren
Rick Deskins
- Company Name: Thermwood
Re: Export to REAL Excel
There is a link at the top of the cutlist. (Export Cutlist To Excel) It open an excel file located at C:\Users\Public\Documents\Thermwood\eCabinet Systems\temp\cutlist.xls
Rick Deskins
Jon Forsgren
Thanks for the come-back. That worked fine so far. Only problem now is that all dimensions are Text! Trying to do a formula, but have to go to each measurement and delete quotes. Anyway around this? Tried formatting cells, etc. No good.
Thanks, Jon
Thanks, Jon
Rick Deskins
You can do a find and replace. Find " and replace it with nothing. Some people write excel macros to manipulate the data. Scott Marshburn is a good resource on working with the cut list and excel. I think he has some videos on youtube. You may search this forum and find some of his work.
Rick Deskins
- Scott Marshburn
Hi, Jon. here's a couple of videos that might help you.
https://www.youtube.com/watch?v=jfalIKP ... A&index=32
https://www.youtube.com/watch?v=AAQDq4Q ... A&index=31
I hope this helps.
I hope this helps.
Jon Forsgren
Bada-Bing!
