Aspire GCode
Justin Wallace
Company Name: Home Design by Justin
Aspire GCode
Post by Justin Wallace »
Could someone take a look at this code? I keep getting an X Axis out of bounds error. We have the Cut Center machine and I am using Aspire to make a simple door hanger. Our G52L1 is at X = 121.70 and our Y = 61.90. I am using a 1/4" mdf sheet 24"x24". This is our first time trying to run a code so we are a little lost. I am also using the Thermwood ATC 91000 post processor. If you need any more information I will do my best to provide it.
Thanks so much!
Alabama A.zip
(23.63 KiB) Downloaded 782 times
Will Williamson
Re: Aspire GCode
Post by Will Williamson »
The post processor is the problem call Thermwood tech support in the morning and they will help you get it straightened out The software comes with about 3 dor 4 different post processors for thermwood Do a search on this forum for Aspire post processor the one from check this out http://www.thermwood.com/forums/viewtop ... +processor
Will
http://www.willmade.com
Company Name: Halls Edge Inc
Re: Aspire GCode
Post by Josh Rayburn »
Justin,
The "use offset" checkbox in Aspire could also result in a good post processor creating out-of-bounds code coordinates. Make sure that box is unchecked.
Hope this helps,
