Diagonal corner cabinet problems
Stuart Douglas
Post by Stuart Douglas »
I have this cabinet that displays correctly, but does not nest or cut correctly. The top, deck, and fixed shelves are nested and defined to cut as pieces that are only a quarter of an inch wide, despite being correctly displayed in ECabS. Not sure how to remedy, or if I'll have to design this again from scratch in a different manner. Anyone run into this problem before?
diag cab.zip
(167.64 KiB) Downloaded 603 times
_____________
NVME SSM2HD 1TB NTFS
Joe Soto
Re: Diagonal corner cabinet problems
Post by Joe Soto »
Not sure why but change if you change your blind dado placement from 2.19" to 2.25" it will fix your cabinet.
Stuart Douglas
Joe Soto wrote:Not sure why but change if you change your blind dado placement from 2.19" to 2.25" it will fix your cabinet.
That is a strange solution, but it works! I had set those blind dado insets to remove the tab created at the back of the shelf (and the top and deck, incidentally) and never looked at them again. Thanks for sleuthing that out. :beer:
_____________
