Suggestions on how to drill three sets of shelf pin holes
Carmen Addamo
Post by Carmen Addamo »
Closet project where it is necessary to drill three rows of holes. How do i set up for the center row (for adjustable hanging rod) at a specific distance from the front (or it could be referenced from the back) edge. I would also like to drill uprights that do not actualy contain adjustable shelves.
I did make a pattern in part editor but I don't want to have to click 150 holes when using "cut pocket using closed contour" on every cabinet side that needs this detail.
Any suggestions would be appreciated.
Thomas strembitsky
Re: Suggestions on how to drill three sets of shelf pin holes
Post by Thomas strembitsky »
maybe set it up as hinge hole pattern and add a door as a phantom part?
http://www.trueform.ca
CS43 cnc
tim lucas
Post by tim lucas »
Is there a reason you cannot use shelf pin holes? You can mark the shelves as Phantom parts and they wont cut.
Tim
www.TLCW.us
Clint Buechlein
Company Name: Thermwood Corp
Post by Clint Buechlein »
Carmen Addamo wrote:Closet project where it is necessary to drill three rows of holes. How do i set up for the center row (for adjustable hanging rod) at a specific distance from the front (or it could be referenced from the back) edge. I would also like to drill uprights that do not actualy contain adjustable shelves.
When in Part Editor, the Windows shortcut Control + A works to select all geometry.
Carmen Addamo
Thank You all for the help.
JR Allen
Company Name: JRs Woodworx
Post by JR Allen »
There is a setting for adding a center row under Add Shelf settings using the apply shelf hole settings
Carmen Addamo
JR Allen wrote:There is a setting for adding a center row under Add Shelf settings using the apply shelf hole settings
Yes, but I don't believe you can specify the location from the front or back edge. It only palces the holes centered between the front and rear holes.
I also don't know what the "single row option" is yet. No time right now to play around
Nat Wheatley
Post by Nat Wheatley »
For the middle row, add a second 'phantom' shelf. Set one of the rows to be off of the part (-3mm), set the other row where you need it to be.
Scott Marshburn
Post by Scott Marshburn »
Hi Carmen. Here is an upper frameless cabinet I drew using a phantom adj. shelf using the single row option. You can check out the construction settings to see how I set it up. Hope this helps.
Std Upper Frameless Adj. shelf Single Row Option.hsf
(344.02 KiB) Downloaded 843 times
David Giesbrecht
Post by David Giesbrecht »
Thanks Clint, This is AWESOME! To elaborate for others wanting to use this.
1- Right click and select "cut/pocket using closed contour" 1st.
2-Then hit "ctrl A"
3-Voila!!
David Giesbrecht
8.00 GB DDR5 2133MHz
NVIDIA GeForce GTX 970 4GB
Z270x-Gaming 5 MOBO
1TB Samsung 960PRO SSD
