Part editor problem when machining
DanFecteau
Post by DanFecteau »
When I nest in eCab I clearly see my pattern on my top stretcher front but in the rolling nest I don't have anything, and the machine does't rout it so why ?? Thanks
test_serrure.esj
(179.99 KiB) Downloaded 668 times
Josh Meyer
Post by Josh Meyer »
Dan,
In order for us to troubleshoot your cabinet we will need the hsf file. If it is an assembly we will need the esa file. These files are saved in the eCabinets folder on the C(root) drive of your computer. You can also put the cabinet/assembly in a room layout and save that job at which point you could send us the esj file. The esj file you have attached to your post is a job file created from a batch of cabinets and the individual cabinet information isn't contained in an esj file saved this way. Sorry about the confusion!
