CNC error code idea
- Thom Davies
- Company Name: Dawn Group
- Country: NEW ZEALAND
CNC error code idea
Hey hows it all going?
When i do a big nest (over 40 sheets and over 4000 lines of code) and an error comes up when i write the code i have to go though all the lines of code to find out whats wrong. My idea is can it (when the error comes up when writing the code) can it tell the user on what line the frist error comes up so we can go stright to that line of code and find out what the error is. Thus saving time and being able to fix the problem stright away.
Thom Davies
Thom Davies
Nick M Singer
- Thom Davies
David Hall
- Brad McIntosh
RE: CNC Error Code Idea
Nick and David,
Both of your suggests are workable, but...
I tend to agree with Thom about the \"pita\" it is to have to go searching for the error line so that you can determine what the error is!
I assume (and maybe wrongly) that Control Nesting (aka Rolling Nest) knows what the error is when it pops up the message box, so.. why not display the Cabinet Number, Part Name, Tool Diameter and/or Operation that cannot be matched, etc.. It's processing this part/operation and writing this kind of stuff (or some of it) out to the CNC code on the error line anyhow, no?
Better yet... have the error or errors (if there are multiple ones) and the related info that I mentioned above, written to a listbox on the screen with the option to print them out on the printer! (An error report - nothing fancy) AND since the CNC code has errors in it anyway - don't even generate it. (No need to since the proposed listbox/printed report has all the info needed to fix the issue(s)! An we don't want anyone accidentally running this erroneous code, do we?)
Just my 2... errrr 15 cents worth. <smile>
Nick M Singer
David Hall
- Larry Epplin
We will work on generating a detailed result for the no tooling available error.
The LWPolyine feature is NOT a layer name option. It simply means that Control Nesting now supports this type of DXF entity. In the past the DXF Import utility had problem with this. LWPolylines are a form of Polyline that CAD systems use in DXF to minimize data size. It stands for Lightweight Polyline.
