Single Tool Pass Doesn't Obey Max Penetration Settings
Tommy Wieler
Post by Tommy Wieler »
Hello again!
I would like to be able to run a single tool pass that obeys the max penetration settings that are set for that tool in profile modeler. Right now, to achieve this, we need to do an enclosed path that runs all the way around the part, so it ramps down and obeys the max penetration. This wastes material and time. Could the software be tweaked so that a single tool pass, as drawn in attached file, would obey the max penetration settings? In this case, it would repeat the same tool pass over and over until final depth is reached. This would be GREAT! Thanks for your consideration, and have a GREAT weekend everybody!
ControlNest6-14.zip
(2.58 MiB) Downloaded 759 times
Mdf Crown Fold - Single Line Pass Test- .zip
(200.25 KiB) Downloaded 759 times
Clint Buechlein
Company Name: Thermwood Corp
Re: Single Tool Pass Doesn't Obey Max Penetration Settings
Post by Clint Buechlein »
Tommy,
The software engineers took a brief look, and it appears this may be a bug. There is some code in there for it to be obeyed, but not in other areas. It will take some development, but we will look into it.
Tommy Wieler
I see the new CN update 6.16 says that this problem was fixed!!! Cheers to the team at Thermwood! You're the best! I'll report back here once I've had a chance to try it out
Tommy Wieler
Problem is indeed fixed! Had a chance to try it out today, and it works like a charm! Thanks a lot, Team Thermwood!
