Greetings all!
Is there any way to change how the machine does ramp-ins? Currently the bit starts at a corner of the piece, then ramps in, cuts the outline, then finishes the outline up to the end of the rampin. This means that the bit gets pulled out of the material partially along an edge, leaving a little ridge that can be very annoying for the sanding crew to get out. Can it be changed to where the ramp in starts close to the end of the corner, then ramps in toward toward the corner of the piece, ending precisely at the corner so when the outline finishes, the bit gets pulled out of the material right on the corner?
