Is there a way to change the default values in the dialog where you can set 5-piece door parameters like rail and stile width, cope depth, etc? I can't find anything. Thanks
Hi Donald.
You can do this in settings and preferences. Click on Default 5 Piece Door Details for Cut List. This opens a dialogue that will enable you to establish default settings for five-piece doors. The settings entered here will only be used if the door or drawer front did not get a detail setting put on it in the designer. I hope this helps.
Scott.
