Hi,
I want to cut 2 rectangles , side by side out of a panel. I want to fix the distance from the panel end to the outside corner of a cut out. Not a problem with CM. I also want to fix the distance between the cut outs. Again, not a problem. But when I resize, I want to have the cut outs resize equally. Is there a way I can do this?
Hi Sean here is a link to a video that I did on creating a 1 piece flat panel door https://youtu.be/LS97b0r1jEI?list=PLsaj ... U0e2&t=805
This link should start the video at the section where I show how to add the constraints for a 2-panel door.
