John J. Desmond
Posts: 242 Joined: Wed, Oct 24 2007, 9:58PM
Post
by John J. Desmond » Thu, Aug 13 2020, 1:44PM
When I add a finished end the toe kick notch will not extend to the bottom of the face frame. How do I get that extended?
Scott Marshburn
Posts: 867 Joined: Sat, Mar 05 2011, 7:29AM
Post
by Scott Marshburn » Thu, Aug 13 2020, 2:40PM
Hi John, Using the Fx editor for the bottom inset on the deck you should be able to set the bottom inset for the deck to be the bottom rail width-the deck thickness. This will make the toe kick notch flush with the bottom of the bottom rail.
John J. Desmond
Post
by John J. Desmond » Fri, Aug 14 2020, 11:30AM
Thanks for the reply Scott. I will give that a try.
