Fixed shelf losing constraints
Hi Guys
Is this repeatable for anyone else?
In the attached cabinet I am losing the front and back insets when I adjust the cabinet construction settings.
So take into shelf editor.
S
Highlight green both shelves
C for construction settings
Then Fixed shelf construction parameters
Then flip, tenon bottom side to reverse the tenon face side
then ok to go back
then ok to go back again. The cabinet rebuilds and looses the fixed shelf construction settings
It also happens when adjusting the tenon gap, for example 20 to 40mm
Thanking you
Mark
Andrew step base.jpg (7.6 KiB) Viewed 6102 times
Andrew step base.hsf
(1.11 MiB) Downloaded 567 times
Clint Buechlein
Company Name: Thermwood Corp
Re: Fixed shelf losing constraints
Post by Clint Buechlein »
Mark,
This is as expected. When you select multiple shelves the construction settings that load are what the default settings are. You then apply the default settings to both shelves so your insets are now what the defaults are. You'll need to select one shelf, make changes, next shelf, make changes, etc.
Okay, that make sense.
Thanks Clint
