I noticed that when using Conventional with Outline Non-Final Pass Climb, the ramp in location is set so that the END of the ramp is located at the corner of the part. When using the single-pass outline cuts, the BEGINNING of the ramp is set at the corner of the part. I would love to be able to combine those two configurations: use a single-pass outline cut and specify the ramp-in to end on a part corner. Is there any way this can be done, and if not, would Thermwood be willing to consider making this an option in a future update?
