Possable to change file extensions?
Chris B Campbell
Post by Chris B Campbell »
So I have a really complex job, bunch of radius's and so on. I also use Bobcad. I use for the more complex cutting and dimension. Is it possible to change Thermwood's file extensions, HSF or ESA to something Bobcad could digest... Like DXF, CAD, DWG, or bbcd
thanks, Chris
Scott Marshburn
Re: Possable to change file extensions?
Post by Scott Marshburn »
I don't know if this will help or not, but you can take the cabinet or assembly into the line drawing editor then from there you can export it as a dxf file.
