Using plywood for door panels
Post by Donald Thomson »
Is there a setting somewhere that I can specify to use 1/4" plywood for door panels? Or is there a way I can have eCabs tell me how many square feet of 1/4" door panel I need for a project?
In the sizing details for cutlist dialog when setting up my doors, I can specify different parameters, including door panel stock, but it seems I can only use solid stock, not plywood. TIA!
Scott Marshburn
Re: Using plywood for door panels
Post by Scott Marshburn »
Hi Donald. You can set up a board stock named 1/4 sheet stock. Then export the cut list to excel. In excel you can extract the panel sizes using get and transform AKA power query. You can calculate the square footage or even export the panels into eCab. batch. I have a series of videos on how to creat a batch export in excel [youtube]https://www.youtube.com/watch?v=id6tBZK ... A&index=25[/youtube] is the link to that playlist if you are interested.
Scott Marshburn
Hi Donald. You can set up a board stock named 1/4 sheet stock. Then export the cut list to excel. In excel you can extract the panel sizes using get and transform AKA power query. You can calculate the square footage or even export the panels into eCab. batch. I have a series of videos on how to create a batch export in excel.Here is the link to that playlist if you are interested.
Thank you Scott! I'll take a look at the video's.
Scott Marshburn
You can email or pm me if you need any help getting this setup.
