Thermwood CS40 With Fusion 360
TomStevens618
Company Name: Halls Edge
Post by TomStevens618 »
Hey Guys,
I have a Thermwood CS40 that I'm trying to get fusion 360's cam software working on. I don't fully know if it's possible, I've spent the last few months digging though what ever I can find for information on the internet. I'm hoping someone here might have some insight on what I could do to have this work with our machine.
So far I've been able to edit a Post Processor to get it as close as I can to working, and I've attached 2 iteration of the .CPS here. One would do almost everything I need but it seems like I can't adjust the Z shift from cutting at it's maximum height. The other will go to the z coords it needs but will then get a y axis error.
Any help or direction will be appreciated. And if I'm posting this in the wrong forum/area please let me know.
Thank you,
Tom
Thermwood PP for fusion .zip
(40.4 KiB) Downloaded 682 times
David Giesbrecht
Re: Thermwood CS40 With Fusion 360
Post by David Giesbrecht »
Not sure if this will help or not but with using Mozaik Post Processor on our CS43 we have to use a negative factor to make the machine calculate right. If it's just the Z axis maybe there is a setting somewhere to adjust the reference point. 0 top of the material or 0 bottom of material.
David Giesbrecht
8.00 GB DDR5 2133MHz
NVIDIA GeForce GTX 970 4GB
Z270x-Gaming 5 MOBO
1TB Samsung 960PRO SSD
