add new empty sheet off fall bug
Thomas strembitsky
Post by Thomas strembitsky »
this is a weird one.
load a job with one piece in control nesting, nest x or y, add a new empty sheet and nest, confirm that the empty sheet is is removed. the drawings with show the sheet and its off fall as being cut. but when you cut it does not do outline cuts for the off fall. and if you print a label for it you just get $-1$ with half a barcode
http://www.trueform.ca
CS43 cnc
Clint Buechlein
Company Name: Thermwood Corp
Re: add new empty sheet off fall bug
Post by Clint Buechlein »
Do you by chance have your off fall set as Save Only in Settings for the group your part is in? Trying your steps with Cut Full Perimeter I'm not seeing any issues.
Thomas strembitsky
i have cut full perimeter selected. with ignore settings grouping checked off
CS43 cnc
