When I try to run an easy link job, everything's look ok till I try to start the program at my 2nd sheet, I get program error 3420 \"macro file does not exist\" ???????
I've reviewed your cnc files and also your machine type, the M901 code is a fixture offset code used on dual table machines. Your machine (according to my records) however is a single table machine and only used the G901 and G902 codes. Therefore when your machine tries to exicute this code, the macro does not exist. This would be due to the Dual Table setting in the SETTINGS of control nesting.
