V-5 Nesting issue
Michael RA Greschuk
V-5 Nesting issue
Post by Michael RA Greschuk »
I took this file and nested it at the machine and the deck,fixed shelf and back which are normally not a flip operation in version 4 turned out to be in version 5. All machining can be done from the top side so it doesn't call for a flip :?: The only thing I did diffrently from my normal procedure would have to do with adding edgebanding in the edgebanding editor :) :?
Last edited by Michael RA Greschuk on Tue, Sep 12 2006, 2:02PM, edited 1 time in total.
Michael RA Greschuk
I tried to recreate the cab with a standard lower without edging with the same results :?: :?: :?: Am I missing something :? Here is basically the same cab created in V4 but saved inV5 No flips :? :oops: :oops: :oops: Guess I missed the check box for single sided material when i created my material. Sorry for the post
