Me or a BUG?
Rob Davis
Me or a BUG?
Post by Rob Davis »
On attached 51.5\" tall upper cabinet, when I put in an adjustable shelf and drillholes, It goes wacko.... wants to machine an hourglass pocket of 48\" long and 10\" wide (estimated). When I nest it in eCabs it shows these shapes. I wondered if it was graphics so I tried it on the machine and it tells me that there is no tool between 9.8\" and 4.3\" to make this pocket.
I am trying to make a tall upper with adj shelf. Deck and top are blind dado into sides and back and the back is full into the sides. I am using build 12 of V5 and I know I am behind at least one but I read all the troubles people were having so I am waiting for the all clear. So, did this get corrected in next build?
The base cabs machined no trouble. I am also having trouble with stray dados being machined for adjustable shelves where I want holes. (I get both).
Hopefully this is something easy since I am in the middle of this job. A fix for this would be a great Christmas present to me.
W1251.5.hsf
(605.47 KiB) Downloaded 624 times
Walker T Scott
Post by Walker T Scott »
Rob,
You have your dado thickness set to .5% change it to 50% for your deck and top and this will fix the cabinet. We are looking in to why the hourglass shape is showing up in nest.
