Door / Drawer Material missing in the cut list
KevinDunn
Post by KevinDunn »
Hi All,
I have another rooking questions here. When I generate a cut list for a given cabinet, it leaves off all materail required for the doors and drawers. This seems to happen when I change the doors to something other than the standard slab.
If I bring in a standard libray cabinet, do nothing to it and then generate a cut list for it, all material shows up correctly.
I am sure I am missing a \"magic checkbox\" somewhere along the way.
I appreciate any help you could provide
Kevin
Dickey Beckham
Post by Dickey Beckham »
Kevin
Only a 5 Piece Door & Drawer Fronts Are Supported in Cut List if you use
Slab Drawer Fronts like me, Do a Search for Board Stock Questions
a Post by Dan Epps will Help you, Some what It did Me.
Kevin,
When you select a door to use, make sure you select either the \"Alternate Source\" or \"Build in House\" radio buttons in the Door/Drawer Front Designer or the doors won't show up in the cut list. Also make sure you click on the \"Details fr Cut List\" button in the designer and enter all of the information there.
KevinDunn
Post by KevinDunn »
Kerry,
That did it, I was not selecting the proper radio button.
This software is so much easier with my eyes open. :shock:
