Part Editor Arch
Chris Say
Part Editor Arch
Post by Chris Say »
I am trying to route a rectangle into a part using a custom made profile tool. On one end of the rectangle the side is not straight is is arched. As soon as I apply a tool with a depth an error \"Internal algorithmic ...\" pops up. I can apply the tool to only an arch and only the rectangle and it will work. But when the two are combined as one function I get the error. I will attach the part I'm talking about. It should still have the route path I need.
Arched Panel.hsf
(75.95 KiB) Downloaded 761 times
Brian Rowland
Post by Brian Rowland »
the file you attached is a rectangle back, there is no arch.
\"Do, or do not. There is no try.\"
Chris Say
Post by Chris Say »
click on the part and go into part editor to see the arch.
Todd Miller
Post by Todd Miller »
Chris,
Maybe Check the tool you created for errors. Could you attach the .tol and .x_t file. Post those files and we can take a look at them.
Chris Say
Post by Chris Say »
It won't let me attach the .x_t files but here are the .tol files. They make the same look as one of the CMT profiles.
Panel Chamfer.tol
(5.4 KiB) Downloaded 737 times
3_16 Rnd.tol
(5.55 KiB) Downloaded 727 times
Zip the files then post them Chris.
Chris Say
Post by Chris Say »
Here are the .x_t files
Can I zip any files that won't attach?
Panel Chamfer.zip
(4.41 KiB) Downloaded 699 times
3_16 Rnd.zip
(4.77 KiB) Downloaded 726 times
Todd Miller
This is a bug. I have a work around though. Offset your geometry in .4375 (Radius of the tool). Re-tool path with the comp left (radius comp) turned on. Hit apply and then OK. This should give you the result you want. I will report this immediately. Let me know if this works for you.
Chris Say
Post by Chris Say »
I tried to follow your instructions and I still get the same algorithmic error. I may not be fully understanding what you are having me do. Do I need to offset my tool path? And then apply the radius comp? Or do I apply the radius comp and then use the offset to get the tool recentered?
Chris Say
Post by Chris Say »
o.k. now I see the problem the problem comes when the tool is centered. I need to adjust the tool path and use the offset to put it back where I want it.
thanks
