Corner cabinet hardware.
Michael Yeargain
Post by Michael Yeargain »
Can you guys make a square corner cabinet lazysusan door accept the two different hinges needed to marry the doors? I would think a special dialog would be needed for this. But I'm only a cabinet maker not a programer.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Michael Yeargain
Not at the moment Mike. I think they are working on this.........?
32Gigs DDR4
Corsair RM650
I know you feel lonely Mike, talking to yourself and all... :cry:
Maybe someone from Thermwood will see this post and reply soon.
Paul Ford
Post by Paul Ford »
Looking forward to seeing this along with the hardware hole patterns actually working on the cabinet for the hinges so we dont have to use the part editor :)
Michael,
If you are just wanting to add the hinges to the cabinet so that they show up on your bill of materials you can add them by opening the cabinet and going to Define Defaults/Add Items and clicking on Go to Cabinet Items and add the hinges there. This will let the hinges become part of that cabinet.
If you are wanting to drill the hinge holes in the doors then I think it is still back to the part editor.
Michael Yeargain
Kerry, I am familiar with the defaults. However, the defaults do not allow the square cabinet the option to designate the two types of hinges it takes to mount a Lazy Susan door. Inset or otherwise. One can default the carcass hinge for example but not the marriage hinge. And, viceversa.
Thanks for helping to manage this thread.
32Gigs DDR4
Corsair RM650
Michael,
You can add both hinges. Set your first hinge as the \"Default Hinge\" and set the second hinge and mounts as an \"Add Item\" Save the cabinet and now every time you use this cabinet it will have both sets of hinges. I do the same thing for Lazy Susan's. I use \"Add Item\" to have the Susan show up when I place cabinets. You can do this for tip out hardware, shelf pins and grommets, etc. Any thing you want associated to that cabinet that cannot be included in the defaults.
Michael Yeargain
Duh...
I knew that :roll:
Thanks Kerry. You know how things can get lost in the forest because the trees are in the way?
32Gigs DDR4
Corsair RM650
