Is there a way to draw ellipses in the parts or contour editors or am I destined to use true arcs and pseudo ellipses?
Also, when I do my final presentation renditions the lighting is somewhat harsh. If I make it bright enough to see the cabinets well it washes out the floor with blinding white light. Is there a way to make the cabinets brighter while keeping the floor detail intact?
Thanks.
Leo
Ellipses and lighting
- Company Name: NCB Inc.
Try using multiple lights with different properties. Light placement will effect your outcome as well. I would just play around with it.
As for the ellipses.... We can't draw them in e-cabs, but we can import them from any Software that can create a .DXF file(Autocad, Mastercam, ect). You can import these files in the Part Editor/Contour mode. Find the load geometry icon and load it up!
Note: Ellipse must be converted to arcs or broken into line segments before loading it up into E-cabs. If it has the properties of a spline it may give you problems.
- Mitch Cain
- Company Name: M Cain Woodworking
