Hafele Hangs
Hafele Hangs
Looking for a Inset self closing hing from Hafele.
Opening angle 110
Is there one that I can get with
hang,mounting plate and screws in one pack I could not find one
or should I order them seperate
30 Lockers 2 doors in front and 1big door in back
Locker 24 W x78 H x 24 D
For Comcast Co. office.
Thank You George D.
Michael S Murray
Post by Michael S Murray »
Hi George, I am sure you will have to order plate and hinge seperate as there are so many app. for either one they would not package them together, or at least not from any one like hafela or similar dist.
Mike Murray
mike@versatilecabinet.com
Eric Shearn
Post by Eric Shearn »
Hello George,
As Michael had said, you will need to buy the items separate. I looked through the Hafele book and it if you search our site for HF-32917 you will see a slection of hinges that should do what you are needing. As for a plate go to Hafale hinge plates on the site, you will see a slection of plates to choose from. You will want the 2mm height plates to do a inset door. I hope this helps and if you have any questions please feel free to email or call me.
eric.shearn@thermwood.com
Eric Thank You
That helped alot
Eric Shearn
George,
I went back and I was wrong on the plate height. It is 2mm on frameless only, sorry.
I have attached a chart to help. I will be adding this to the store soon.
HafeleHingeChart.pdf
(52.02 KiB) Downloaded 474 times
