Machine won't nest
Machine won't nest
After trying to add a TWD file into the machine and then nesting it an error \"Cannot find nestlib. Exiting\" comes up. I have tried shutting down the machine and restarting it, creating another job with no luck. What does this error mean?
Hi Chris,
I will need more details in regards to the error message your getting. I would like for you to contact me in order troubleshoot this issue. I will then post the resolution once it has been found.
Email: program@thermwood.com
Chris,
I am still unable to get email through to you. However, after looking into this situation, it was apparent that some sort of file structure was missing and needed to be replaced; so the next step I was going to recommend was to run the control nesting update, Repair option.
Let me know if you need any additional assitance.
