Ecab 5 Build 12)
Found a weird problem today. Wanted to change existing kitchen that had door/drawer fronts from \"alternate source\" to a MDF door that I customized with inside/outisde profiles to create a one piece mdf door. When I started, the esj file was about 10 Meg. The first thing I noticed when I started changing doors (from the custom layout area) is that the operation took a long time (several minutes with say 6 cabinets selected). Then I noticed that after I was done, the nesting would not work and would \"hang\". Have a total of 19 cabinets. Ran into memory limitations when trying to save file - had to change a door at a time and save, door at a time, save, etc, etc. Noticed that that 10Meg esj had more than doubled by the time I had changed all my doors to that one piece mdf door.
Computer is a dell Precision M70 with 1Gig Ram. Not sure what video is in it.
Any help would be appreciated.
Jeff Whippo
MDF Door Causes Excessive Memory Allocation
Dan
Nope just 19 upper/base cabinets and a total of 5 drawers. Nothing fancy, no molding, etc, etc, other than the attempt at adding one piece raised panel mdf doors. With each door I added, the system bogged down even more. Lots of times when doing a file/save, I'd get an \"out of memory\" error and simply could not save. Then I'd reboot, come back in, change one more door to raised panel mdf, save (maybe) and repeat the process untill they were all saved. Then when I go to the nest area and to the next, the system hangs. Actually, hang may not be a good word - it was probably actually doing the nest, was just taking a very long time. I killed ecab after about 15 minutes.
Jeff
Jeff
