I was hoping to do a trial run with some d-fronts tommorow and noticed that the dovetails do not show up on the d-box front #s 12 and 2 on the nesting diagram....
no dovetails on d front.jpg (74.28 KiB) Viewed 2837 times
Roger,
From the picture you have submitted, it looks like you may have the construction setting for the front of the d-box set to blind dato. Try changing the construction for that side to dovetail, then re-save. Then set the saved d-box to your default. If you want to attach the hsf file for the d-box, I can take a look at it for you...
