I know how to use the hole pattern editor....however I wanted to create hole patterns and then associate them to display panels....not for hardware...is this possible?
What is that other file extension when trying to save?
creaitng hole patterns for thing other than hardware
- Roger Erismann
Wood Butcher/Case Maker
- DanEpps
- Company Name: Dan Epps
After reading your post in the CNC forum, I realized what you want to do Roger.
It is going to be so easy you will kick yourself for dreading it
Take one of the existing parts with the holes into Contour Mode of the Part Editor. Right-click and choose Create Edges from the context menu.
Save the geometry as an x_t file and use it over and over and over again.
That's all there is too it.
- Roger Erismann
- Roger Erismann
