Hello,
This is my first post. I have used eCab since ver. 2, but just joined the forum. Most of my work is in remodeling or in matching existing cabinets or duplicating something the customer already has. I have not used all of the features, but, I'm trying to learn. My question today is about holes associtated with hinges. When sclecting a hinge and associating a hole pattern, the file reads something like this:
\"hinge-Salice-Series200-bore_3.ptn\". Is the the number at the end, in this case a 3, the tab distance on the door?
This software is the best and Thanks to Eric and Thermwood I have my software running again.
Usually that is the case...with Blum hinges in the whole pattern file...you can allways load up a hinge and then use the line drawing editor to verify your bore distance
