multipanel doors
Joseph Swift
multipanel doors
Post by Joseph Swift »
Message
Kurt Raschke
Posted: Thu, Sep 29 2005, 9:19AM Post subject: double panel doors
can anyone tell me how to make a double panel door with the door/drawer editor. I have a 70 inch tall door that I am going to be putting a mid rail in and wanted to be able to draw that up. any help will be greatly appreciated. thanks.
Back to top
David Hall
Posted: Thu, Sep 29 2005, 9:35AM Post subject:
Sorry, eCabs does not currently support multi panel doors.
For display purposes, I would place one door on the lower half with a top inset/reveal equal to the size of the top panel. Then manually place a door as a display object (about 2\" taller than the opening) so the lower rail and upper rail, merge as one, creating the appearance of one door with a mid rail.
Be sure the display door is associated to your cabinet or you will loose it when you save.
Alternatively, if the door style used a flat panel, you could place a display board or panel on it to simulate the mid rail.
Dave
_________________
David Hall
Hall's Edge Inc.
eCabinets Machining Services
http://www.HallsEdge.com
Back to top
Joseph Swift
Posted: Yesterday at 4:40PM Post subject:
Does the same still hold true in V5 or can multi panel doors be created now? I have used display cubes in the past and it works fine, just a little cumbersome.
Joe-
Todd Miller
Post by Todd Miller »
No.... refer to David Hall's post.
