sending files via email
justin mason
Company Name: IWS
Post by justin mason »
I have been using production sharing with a shop 45 min drive away.
I send the esj. file via email, a few have gone through properly.
the problem is that what shows up on his computor and what is on my computor are not always the same.
-dados depth change,
-does not display edgebanding,
-wacky material texture.
-jointery sometimes changes
-part editors will not cut properly
not all these at once, but usually something is weird and we can not figure it out.
clear design
Are you making changes to any of these settings from the custom layout and NOT saving them?
justin mason
Company Name: IWS
no, I'm sure its something I am doing wrong, but I have brough my laptop and opened the same job I just sent and get these problems. is there a better way to send
clear design
justin mason
Company Name: IWS
to be more specific, for example- I will design a cab with 5/16 deep blind dado, send it and the left side is 5/16\" but the right is 3/16.
my computor shows both 5/16 his shows the 5/16 L 3/16 R
clear design
Can you post a cabinet or job that you have trouble with?
justin mason
Company Name: IWS
-this job 3-16-2007 I am assembling today. it has the different dado depths on the deck cabinet no. 4.
-the second job 5-1-2006 the router would cut all the through where there was a dado on cabinet # 14 girls vanity it would grab the bit for cutting the dado and just cut through. then forget about the part editor cut.
clear design
justin mason
Company Name: IWS
dan, sorry I forgot to attach the files, I have tried 4 times now to send the files and they will not go through, maby I can try later in the evening.
perhaps that may be my problem, I use aol and when there is a lot of traffic it is very slow.hmm? thank you in advance,
clear design
That shouldn't cause a problem like that. You can email the file to me if you would like.
Justin D Melhiser
Post by Justin D Melhiser »
Justin
If you would please send me your cabinet files to cabinets@thermwood.com and I will take a look at them.
justin mason
Company Name: IWS
something that happens to me, maby a clue:
say I design a cabinet( using global full dado, so I do not change the depth anywhere else, maby chang to butt joint like on a back ), save it, then change a few things like add shelves or partitions, remove back, etc. then return to main in cab editor,
then explode the cabinet- sometimes dados are all the way through and you can see the end of the deck sticking out, or the depth has some how changed...I can go to construction parameters and adjust to what I had, then it stays. but it is always a surpise wich part and how much it changes.
I will try to post the job with the most wackyness. McConnell
check #3 coffe upper
I hope you can tell me \"oh your just doing \"this \"problem solved.
thank you again for the support and responses.
101 McConnell residents Snowmass.esj
(5.68 MiB) Downloaded 905 times
clear design
