cutting mdf doors
Roger Erismann
cutting mdf doors
Post by Roger Erismann »
I wanted to show some cut doors to the crew on monday I have included the job file....once again when I nest in ecabs the doors show no machining...I get the deal with the edge profile but the raised portions don't show either....
One door is using the asym tool that comes in the software...
one is using two tools I created
and one is using an asym tool I created...
can someone take a look and see if this will run thanks...
Roger
raised panle.zip
(1.27 MiB) Downloaded 845 times
Wood Butcher/Case Maker
Brian Shannon
Post by Brian Shannon »
Roger,
I took the job file to the shop. The raised panel doesn't show in RN but does show in Profile Modeler.
Roger Erismann
Thanks Brian...
So we gotta run the doors through the profile modeler...great!!
You working on sunday too?
When I bought my first tablesaw the older guys said I bought an obsesion.....what would they think about CNC?
Thanks again
Brian Shannon
I had the in-laws at the house over the weekend. As soon as they left (for Chico) I had to come down and finish a job for delivery in the morning. I have a 60 yr old Italian craftsman that works for me. You should see the way he looks at the router when it's doin' its thing...
Roger Erismann
We cut a door today...it came out OK...
The MDF fuzzed up pretty good...I was thinking of going with courmatt or any diamond abrasive bit to cut back on that...
Any thoughts..
Nick M Singer
Post by Nick M Singer »
Hi Roger
What cutter are you using currently?
Joe Soto
Post by Joe Soto »
Roger, Are you using double refined board? Also, I believe it was Forrest who suggested a 50/50 mix of water and wood glue brushed on the fuzz and let dry. It will sand much easier.
Joe
Roger Erismann
we used a compresion bit.....vortex I believe
I've done glue sizing alot and was hoping to minimize that as part of the process...
We will give double refined a try
Zach Froble
Post by Zach Froble »
I will second the refined MDF, we use it for our doors and paint grade mouldings and parts. It really cuts down on the \"fuzz\", but if you want to cut down on coatings you will still have to do a little sizing.
We use ML Cambells Clawlock for priming and you still have to do some glue sizing. Any one found another primer to reduce the number of coats to seal.
Zach
Lyndan Designs
Machining and CAD Services
Brian Shannon
Roger,
A Comp. bit will cut the detail using the upcut as it cuts from the tip. Try a downspiral in a conventional direction. That, and the superefined MDF will help alot.
Nemanja Vujkovic
Post by Nemanja Vujkovic »
Hi!
Roger was wrong. We are using 1/4\" ball nose bitt. And all we could find is upcut. Is there a ball nose downcut???
Roger Erismann
What nano said and the follow up question is
Same question for hardwoods,,,,
We are using the profile modeler for our profile cuts..
Brian Shannon
I just checked and I have been using a 3/16\" dia. upspiral ballnose and have a really nice surface finish. A downcut would be even better if available.
