Local Texure Problem
John Lawrence
Post by John Lawrence »
When i try to bring some of my library cabinets into the cabinet editor or into the custom layout i am getting a message saying that local texture is having a problem loading. The cabinet will load but it leaves a smaller image of the cabinet inthe target axis or the middle of the room and it cant be selected or deleted. Has anyone had this problem before.
I think it might be closely related to my drawer boxes as i dont remember it happining to cabinets with doors.
Also the problem started with a message saying cant read hoops or could not open hoops or something similar, then after i used the cabinet a few more times it seems to have evolved into what you see in the pic below.
Any ideas?
John Lawrence
I just restarted my computer and tried opening the same problem cabinet again and it has gone back to the start of the problem again. Below are some pics of what it was doing before it went onto the problem as pictured in my first post.
I click ok on each of these ones below and the cabinet opens no worries.
After loading the cabinet a few times it goes to the local texture and little cabinet with the circles prob.
Walker T Scott
Post by Walker T Scott »
John,
Could you post your cabinet please
John Lawrence
Poblem cabinet
3Dr 1=122nr 2=122wr 3=122wr.hsf
(388.31 KiB) Downloaded 988 times
John Lawrence
Poblem cabinet
(388.31 KiB) Downloaded 973 times
Scott G Vaal
Post by Scott G Vaal »
John,
The issue with this cabinet is due to the fact that the equal sign exists in the file name. It appears that the Hoops stream format is not liking the = sign during the load. If you rename the cabinet(s) without the = sign, they will load just fine. We will look into why this dislikes the equal sign and either block the ability to save with this character or resolve the issue it has with it. For now, refrain from saving cabinets with the equal sign in the name. Sorry for the inconvenience.
John Lawrence
Thanks very much
