sizing rails on raised panel cabinet sides
davidklehn
I am trying to make raised panel sides with 3 1/2\" rails but they keep coming out the same as the stiles which are 2 1/4\", also what if the top rail is different size than bottom.how can i do these two things
Michael Yeargain
david klehn,
Are you using a cope and stick door or a miter door? I don't know of a way without using the parts editor to creat a door with different top and bottom rails. However you can use any of the stile and rails to change the sizes of them. Make your modifications and select build in house.
Mitered doors will not allow different size stiles and rails.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
32Gigs DDR4
Corsair RM650
davidklehn
davidklehn
- Kerry Fullington
David,
You can't do what you want with a door at this time. There has been talk of a \"Door Designer\" in the future which would let us make custom doors as well as end panels and wainscot with a different width for each stile and rail. Here is a link to a thread that discusses several ways around this problem for now.
davidklehn
- Kerry Fullington
Mike Seisser
- Company Name: NCB Inc.
