Has anyone else had any problems after updating to IE 7?
2 or 3 times a day IE says it has to shut down and all work is lost.
Ted
Internet Explorer 7 problems
Brian Rowland
- DanEpps
- Company Name: Dan Epps
I've been using IE7 for some months now and have yet to have a problem with it.
What kind of add-ons are you using? If they are not IE7 compatible, they could be causing problems.
Open the Tools menu and selsct Manage Add-Ons. That will open a dialog that shows all add-ons. You can choose from those currently in use, those that have ever been used or those that run without permission.
Start with add-ons currently in use. Make a list of the add-ons then disable everything. See if that corrects your problem. If it does, you can re-enable add-ons one-at-a-time until you start having issues again. Make a note of what you enable as you do it. Then disable the last add-on that you enabled to see it the issues go away. If so, you've found the problem...if not, disable the previous add-on in the list.
IE problems
Brian,
Yes I have that problem also.
Dan, thanks for the suggestion. I will try that.
Ted
Ted
