Yet another time wasting bug and omission
Nick M Singer
Post by Nick M Singer »
I really am on a roll this afternoon..., I find that if I change doors or drawer fronts in plan view by selecting a group of cabinets all my cabinets jump around, sometimes even halfway out of the room. Another thing that should be attended to is the fact that you can not change the cabinet end material either through change sheet stock or change doors . You have to delete the cabinet end and then reapply it, Very painful!!!
Michael S Murray
Post by Michael S Murray »
Hey Nick,
You can change the material for an end of a cabinet in the room, highlight the cabinet and then go to change material, make the change and then check your cutlist. It wll reflect the change on the cutlist, BUT the image will not change. You can also pull tthe cabinet into the cabinet editor and then pull up construction settings and make the material change, this will change the image and then you can return it to room correct, A pain yes, but work-around until it is fixed.
Mike Murray
mike@versatilecabinet.com
