Quirk or bug...
Michael Yeargain
Quirk or bug...
Post by Michael Yeargain »
Another problem is with the cabinets with double doors compaired to the cabinets with single doors.
The single door cabinet has a 23 31/32\" door and the double door has a 24\" door. Same settings, same seed cabinet, same fixed shelf opennings. just added two doors instead of one.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Check your double-door gap Mike.
Michael Yeargain
Dan,
The double door gap would recon the width of the door right? But, they are the same .125\"
32Gigs DDR4
Corsair RM650
You have a 3/32 bottom reveal on the double-door and a 1/8 bottom reveal on the single-door, making the single door 1/32 shorter.
Sorry...I was thinking about width before--DOH!!! That would have been some pretty wide doors, eh?
Michael Yeargain
If you change the door settings to 3/32\" on both cabinet and re-do the doors do they all show a 24\" door?
32Gigs DDR4
Corsair RM650
If you go into the door/drawer editor and select the door before going into construction settings it does.
Michael Yeargain
I don't know what I was doing wrong, I was deleting the doors entirely and then adding them again after I made the changes. If I select the doors and then make the changes my doors and drawer fronts get wacked. One will taller and the other shorter and the drawer Might stay the same.
Something is going on with these cabinets. With my system of course.
32Gigs DDR4
Corsair RM650
Here is the modified 1 door cab...
1Dr 1Dw.hsf
(622.48 KiB) Downloaded 434 times
Michael Yeargain
Dan,
If you select the 2Dr 1Dw cabinet and go to the door editor. Select the doors and drawer and change one of the reveals.
I changed the bottom reveal to 1 \" just to see if I was loosing my mind, and it did the wack job.
32Gigs DDR4
Corsair RM650
Nothing to worry about Mike, you're just losing your mind :shock: it works fine for me.
Michael Yeargain
wow I just thought I was loosing something I don't have...
Funny thig not so funny is I just reformatted and reinstalled everything and this is why I did that. Because my doors are getting wacked. I can select the two bottom doors and drawer, click on the settings and change any number to rebuild the cabinet and the doors go haywire.
I just finished rebuilding my entire 23/32\" birch directory and was double checking the files. And this is happening...again. :roll:
32Gigs DDR4
Corsair RM650
You're running 5.1 build 2, right? If not, that might be it (I am on the latest build). If you are running build 2, you might try reinstalling the update again.
Hold on a minute Mike...I just double checked and the left door is 23 5/32 while the right door is 23 9/32!!!
Not only that, if I change the bottom reveal back to 3/32, it is still out of whack.
You can reclaim your mind now.
Michael Yeargain
Yippy hurray..
I'm not crazy....
Oh yea he is don't listen to him
Shut up///
32Gigs DDR4
Corsair RM650
Michael Yeargain
Not only that Mike... I mean Dan...
Did you notice any changes in the file size?
Dan
I mean Mike :roll:
32Gigs DDR4
Corsair RM650
