Help on window frames
The window trim is (STL Files) I am trying to put a image in the window opening but . I made up a panel in a stl file to fit in the window opening
I just can not (scale) the image right on the panel and (rotate) it right :?:
The panel I have in it now is just a display cube right now but I need to
put a stl file panel in it so I can resize the hole thing at anytime
Can someone help me on this
George,
There has been a problem with placing images in the Display part Editor from day 1. They will always be \"skewed\". There seems to be no way to rotate them into position properly. The display cube is the best way to go right now.
Thank You Kerry I tryed before 5 or 6 times and gave up
