Line Drawing Editor
Jim Tramontana
Line Drawing Editor
Post by Jim Tramontana »
Is there any way to dimension 5 piece door in the line drawing editor?
I can get an over all measurement but not individual parts, stiles, rails etc.
Jim T
Todd Miller
Post by Todd Miller »
Jim,
If you are in the LDE, hit the \"M\" button on your keyboard. This will show you all of your snap-to points. But, like you said, on the doors you can only get the over all dims.
Scott G Vaal
Post by Scott G Vaal »
Jim,
I case you are unaware of this option: If you set a door up as a \"build in house\", you will get sizes of the individual parts in the cut list. Make sure you set your \"default 5 piece door details for cut list\" settings to match the way you make your door. This is found under settings/preferences for a global setting or can be set specific per door. Hope this helps.
