lost slide holes on cabinets
Ray Jorgensen
Post by Ray Jorgensen »
I've just noticed that I no longer show nor machine drawer slide holes on my cabinets. Have i missed something? a bug in the latest build? If not how do I get them back? The hole pattern is associated to the slide in the cabinet defaults.
Post by Forrest Chapman »
Ray,
This was a bug in 5.1.2 and was supposed to be fixed in some situations. However it was only documented a time or two. Scott Vaal will need to respond to this.
Scott G Vaal
Re: lost slide holes on cabinets
Post by Scott G Vaal »
Ray Jorgensen wrote:I've just noticed that I no longer show nor machine drawer slide holes on my cabinets. Have i missed something? a bug in the latest build? If not how do I get them back? The hole pattern is associated to the slide in the cabinet defaults.
Ray,
We had a issue where hole pattern associations would get removed (room/batch level) if a job was open/active and then the new button was selected in the cabinet editor. This issue is resolved in the latest build. But, with that issue, the pattern would no longer shop up.
Could you post the job and at least one of your cabinets from your library? Any other information on this would be helpful. You can zip the files into one file and then attach it.
Ray Jorgensen
More than happy to comply!! here's a cab and the hole pattern for a 22 in accuride glide.
22 in accuride.zip
(5.16 KiB) Downloaded 392 times
b_18.zip
(278.53 KiB) Downloaded 405 times
Scott G Vaal
Ray,
Was this cabinet ever saved off from a room or batch?
Ray Jorgensen
I used it in a batch but never saved a size change. It very well could have been saved from a room but that would have been a few versions ago. I had holes up until shortly after the first of may. I just got my machine and the first times I cut a cab I got the holes. I noticed after tweeking fits that there were no holes. It would have been after the last update.
