Is there a way to make the holes that you pocket out into a Side of a unit to move with the unit when u say expand or shrink it? So you don't have to remake all the holes because when i make something bigger the holes stay in the same place they were made instead of move with the unit in the same place....if that makes sense...
Take the part that you edited into the constraint manager. (Looks like a \"C\" clamp). There you can place constraints on the pocket and position it where you need to. No need to be exact with the original pockt, as the constraint manager will move this around with the constraints you place on it.
